Home > My Range Rover > A Thousand Days...
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
A Thousand Days...
This weekend is going to be a thousand days with the old girl...
It's been rough, it's been smooth and everything in between. Never boring though. I admit losing faith at times but certain members here helped steering my course through the storm with their advice Bow down .
So far the following have been take care of:
ENGINE
Parts replaced:
RADIATOR
VALLEY PAN
GEARBOX COOLER RADIATOR MANIFOLD+STAT
TOP RADIATOR HOSE
REAR HOSE TO HEATER MATRIX
LOWER RETURN HOSE
EXPANSION TANK AND CAP
VACUUM LINE TUBES
INTAKE MANIFOLD GASKETS
PCV
PCV GASKET
CROSS OVER PIPE (THIN)
WATER PUMP
THERMOSTAT
SPARK PLUGS
IGNITION COILS
TIMING CHAIN SET
TIMING CHAIN GUIDES SET
TENSIONER
HEAD GASKETS
ROCKER COVERS SEALS
TIMING COVER SEALS
VANOS SOLENOID SEALS
IDLER PULLEY
SERPENTINE BELTS
AIR FILTER
OIL FILTER
OIL CHANGE
COOLANT CHANGE
O2 SENSORS ALL 4
COOLANT TEMP SENSOR
CAMSHAFT POSITION SENSORS
TRANSMISSION
COMPLETE GEARBOX 100+K KM AGO
GEARBOX OIL AND FILTER CHANGE X2 SINCE GEARBOX REPLACEMENT
FRONT - REAR DIFF AND TRANSFER CASE OIL CHANGE
NEUTRAL (XYZ) SWITCH
SUSPENSION
FRONT BUSHES
FRONT BALL JOINTS
FRONT DROP LINKS
FRONT AIR STRUTS
BODY
SIDE LIGHT CLUSTERS, FRONT
TAIL LIGHTS
REAR WIPER MOTOR
PASSENGER WING MIRROR GLASS
WINDSCREEN JET SPRAYER RIGHT
WIPER BLADES FRONT - REAR
WHEEL CAPS
BOOT LID GAS STRUTS
A PILLAR TRIM
TOWING EYE COVER
HEADLAMP WASHER PUMP
PASSENGER DOOR LOCK
REAR LEFT DOOR LOCK
REAR RIGHT DOOR LOCK
THIRD (TOP) BRAKE LIGHT
WINDSCREEN TOP MOULDING
BRAKES
PADS
WEAR SENSORS + PLUGS
FRONT ROTORS
PARKING BRAKE SHOES
INTERIOR
BLENDER DAMPER SERVO
DOOR BADGES
CABIN FILTER
REAR SEAT HINGE COVER
INDICATOR STALK
STEERING COLUMN LOCK EMULATOR
...PLUS...
BATTERY
TYRES
The following jobs done:
COLOUR CORRECTION + LIGHT POLISH
WHEEL ALIGNMENT
BONNET RESPRAY
PDC REPAIR
FUEL DOOR LOCK REPAIR
HEADLIGHT WIPERS REPAIR
REAR MUFFLER RESPRAY
BRAKE SYSTEM FLUSH
HDC + LOW RANGE PANEL / SWITCH REFURB
CYLINDER HEADS REFACING
VALVE JOB
ROCKER COVERS POWDER COATING
STEERING COLUMN LOCK REPAIR + EMULATOR INSTALLED AS EXTRA LAYER
IGNITION LOCK BARREL REPAIR
ALTERNATOR REPAIR
MOT VALID FOR ANOTHER 1 SOMETHING YEAR
CABIN FILTER PLENUM REPLACEMENT
And the following extras installed:
RUBBER MATS
LOAD SPACE COVER
WIND DEFLECTORS
FACTORY LEVEL WINDOW TINT
LED REVERSING LIGHTS
SPARE KEY
TOTAL COST INCLUDING PURCHASE 24,000 GBP
Now on 233K km and counting...
I'm really glad I didn't sell this car. Now it's unlikely I'll ever let it go unless (knock on wood) either one of us or both become incurably ill or get the passport stamped...
Here's some "before"
forum photo hosting
uploadphoto
And some after...
uploadphoto
Post #635849 1st Jul 2022 5:20pm
Congratulations, here's to another 1000 or 2.... Thumbs Up Pete
Post #635854 1st Jul 2022 5:34pm
vs322
Thanks, Pete!
Cheers
Post #635857 1st Jul 2022 5:49pm
kevinp
I really like the deep dish wheels. It gives them an eye pleasing depth that modern day 'flat' wheels can't provide. Looks very nice mate.
Post #635864 1st Jul 2022 6:25pm
vs322
Thanks, Kevin
I totally agree about the rims. Many would argue their style is dated. I say they're elegant and at 18" they offer much more tyre options. They really meet my requirements and don't cost a fortune Thumbs Up
Post #635872 1st Jul 2022 7:38pm
