![]() | Home > Off Topic > CNC cut from CAD ? |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
It depends on the material you want cutting, what do you have in mind? BMW i3 Electric Car
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
aluminium sheet Cheers, Greg
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8567 ![]() ![]() ![]() |
I looked at that a few years ago, fine if you want 5,000 pieces, if you want two or three it would be cheaper to get them cast in gold.... |
Aluminium can be complicated with some lasers, they dont like it. Try GKR Sheet Metal https://www.gkrsheetmetal.com/ or here for waterjet cutting (gives a very, very smooth cut. https://www.locatewaterjet.co.uk/ What CAD package are you exporting from? most lasers / cnc etc accept DXF as the import file type. If you want prototype stuff made from MDF, I can lasercut that for you. J BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
CNC cutting with what / what material?
Rjh112 Member Since: 28 May 2022 Posts: 38 ![]() ![]() |
Better off laser cutting with sheet, but it also depends on thickness. One of my guys can normally program a machine from a drawing with measurements without much trouble, If its a part you think can be sold to others it can work out better to have 100 made. |
