![]() | Home > Maintenance & Mods (L322) > Webasto ThermoTest - connecting to K-BUS |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8353 ![]() ![]() ![]() |
All that is way above my pay grade but I do know the Gap Diagnostics IID tool solves your problems, others have tried various different approaches but few have succeeded.
Thanks, I don't think that the Gap tool does any more or less than the Autologic I already have in terms of FFBH functions. It's not really a 'problem' as such, more of an annoyance - something that should work, doesn't... I suspect it's to do with Bus ID numbers, the IPK being the gateway will always be ID0, maybe this is somehow blocking the KKL interface as it won't know how to redirect traffic...
I don't know if the Gap tool does more or less than the one you have, apparently it can do more than the JLR tool... I think it's success is that they have sorted out the connectivity and it is just plug and play.
yorkie3259 Member Since: 29 Apr 2012 Location: Bridgwater Posts: 9 ![]() ![]() ![]() |
have you read through the info in the Disco4 forum https://www.disco4.com/wiki/Webasto_Thermo_Test_Setup
Thanks, Yes - I'm aware of that potential issue, I don't think it's applicable as I have reliable comms to the FFBH with my Autologic unit which uses the IPK as a gateway (as will all diagnostics through the OBDII socket, regardless of whether it's SDD or aftermarket - that's just how it is set up). As far as I remember, the issue with the 'resistor rot' is ghost errors relating to the fan, burner or water pump, the comms area of the PCB is in a different part to that affected by the adhesive.
Well I removed the FFBH today, connected a 25mm hose elbow in it's place as I planned to refurb it in slow time - needn't have bothered! I took the burner out (which had a hard fault for the glow pin) and it looks barely used, so I cleaned it up in the parts washer with a blast of brake cleaner to get rid of any oily residue, stuck in a new burner & glow pin assembly from Webastoo Parts, which came complete with new gaskets, bolts, etc. for a reasonable £80 inc postage, re-assembled, refitted, bled the coolant through and fired it up (ambient was 14deg. C. so just in the window!), at first I didn't think it was working as there was no smoke, it ran for 30 mins with no drama's and shut down gracefully, refitted the wheel arch liner and ticked another job off the list - oh, connected to K-BUS fine with the KKL adaptor once the IPK & climate control was isolated so I think I'm going to find the SJ or somewhere FFBH-side of it and run a twisted pair to a switch, as the sketch above.
