![]() | Home > Technical (L322) > Heater/AC issue - no air from dashboard vents. |
Hitby Member Since: 20 Oct 2017 Location: Middlesbrough Posts: 47 ![]() ![]() ![]() |
Good evening all,
Hi Phoenix,
Yep, it's worth a try - key out for 3 mins, disconnect -ve terminal for 3 mins, reconnect. Pretty generic instructions but I've never had any problems with that sequence on any vehicles of this century.
Thanks, I’ll give that a go first thing in the morning. Fingers crossed! |
Hi Phoenix,
I'd get your battery tested, sounds like the voltage could be dropping quite low on cranking.
Thanks, I'll see if I can borrow a battery charger from somewhere and take it out and charge it off the car. I'll let you know how I get on! |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Has anything changed? I had the same and it was after I’d been messing around with the panel and one cable was disconnected plugged it in and hey presto Current stable:
Any idea of the plug. I’m borrowing a charger but I can’t get it for a couple of days. I’ve got my fingers crossed though. |
Afaik when you pull the top half out it went in underneath facing up instead of the rest which just plug into the back. Ultimately though check they are all in tight and non are missing Current stable:
I took the car on a run and the vents started to work. I've checked the battery with a multimeter and it reads 11.97 so it is low. I'm borrowing a charger today and I'll take it off and leave it to charge overnight. It does seem like it could be voltage related though as they fired straight up after driving for a bit.
If it’s not that it still could the that plug loose - is easy to check pull the cheek panels off leave the screws in and then just pull the module out a bit Current stable:
I've had a chance to charge the battery which seems fine but still having the problem intermittently (more often than not).
Yea passenger and passenger pull the piano black wood trims out word towards the door then you can easily get the module out by pulling it forward - I think you can pull it without getting these out but this gives you a bit more access for 40seconds extra work Current stable:
