Home > Maintenance & Mods (L322) > Heaters
sean mullane
Ireland
Heaters
2012 tdv8 pipes going to the matrix are cold . I recently changed the oil cooler , have I got trapped air ??
Post #635387 24th Jun 2022 6:14pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Try bleeding the system again, sounds like an air lock Thumbs Up
Post #635400 24th Jun 2022 7:51pm
sean mullane
Ireland
Thank you . What’s the best way to bleed it ?
Post #635404 24th Jun 2022 8:03pm
Highroller
The process is in the manual & can be down loaded from the Wiki files. If possible park the car up hill.
I have used this process, but I also run the car up to temperature with the expansion cap Off & the bleed valves undone, (until coolant comes out of the bleed valves & the expansion tank starts to overflow ).
Switch it off & let cool down ( top up as necessary).
Then run it up to temparature again with the cap On, let it cool down & top as necessary. That shoul be adequate, if necessary you can repeat the process.
Post #635456 25th Jun 2022 9:07pm
