Home > Maintenance & Mods (L322) > Classic[?] failures with 100000 Miles 10yo TDV8 FFRR... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8285 |
Reliable..... Hmmm, let me think for a minute...... Pete
24th Jun 2022 2:47pm |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 |
2005 FFRR SC Java Black with Overfinch Exhaust (UK)
24th Jun 2022 3:03pm |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 |
It can be seen as being a bit fun though... these are all textbook L322 failures.
24th Jun 2022 3:13pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
have your oil cooler checked. |
24th Jun 2022 3:18pm |
that oil cooler with the textbook leaking gasket I've had already, so I'm good...I think "it needs some intelligence to undestand you may not have enough" |
24th Jun 2022 3:24pm |
Turbos next then.... Pete
24th Jun 2022 4:08pm |
Then brake pipes, airbags, suspension bushes, battery, alternator, starter.... I can go on for ages..... Pete
24th Jun 2022 4:09pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1222 |
Interested to know what the symptoms of the 'failing egr' is please. |
24th Jun 2022 4:44pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1196 |
Ergobyte, ignore Haylands, I think he's trying to give you a nervous breakdown IF....you have not had one already
24th Jun 2022 4:58pm |
Thanks Merchy,
24th Jun 2022 6:14pm |
that's the thing...the only warning I had was a direct full red "DPF full, go to dealer" warning and a car in limp mode. I never had a DPF yellow warning. Went to the dealer and that's what. Couldn't do any regen in limp mode (I checked on the wiki) so basically I was The head mechanic told me that a failing EGR like mine will never recover and its "warning" is impossible to erase. "it needs some intelligence to undestand you may not have enough" |
24th Jun 2022 6:23pm |
My bad ! DrRob did the Job ! see here :https://www.fullfatrr.com/forum/topic44115.html?highlight=4+4&start=75 "it needs some intelligence to undestand you may not have enough" |
25th Jun 2022 12:01pm |
