![]() | Home > Technical (L322) > Please help!! Gearbox fault and codes |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2568 ![]() ![]() ![]() |
Have you recalibrated the transfer case motor? It wouldn't be expected to cause a gearbox fault but worth a try. |
New2merover Member Since: 17 Jun 2022 Location: Lakebay WA Posts: 11 ![]() ![]() |
I have not, what is the procedure for doing that? Thanks for your help!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
I think you need some in depth JLR diagnostics done, it will read deeper than a generic reader.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
It sounds like you definitely need to recalibrate the transfer case motor, once they’ve been apart or removed they can forget the correct position, unfortunately as Haylands says you will need specialist diagnostic equipment to do this as most generic ones will not have the correct software to perform the reset.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
That DTC refers to the extended time it's taking for the E clutch to apply. Does the transmission lose drive immediately after the 3-4 upshift? Can you drive it round happily enough in 1st, 2nd & 3rd gears? Phil |
I take it your a newcomer and not used this site much before?
Thanks for the info so far everyone!!
Hi guys sorry it took so long to respond. Life gets crazy! So Phil it does drive fine in 1-3 but I can’t drive it like that forever. My thought is I’m going to replace the transmission. I found one rebuilt but I’m not sure it will fit mine. Mine is a 2011 vin salmf1d41ba334918 the one I’m looking at is a 2012 vin salsk2d43ca756327. Is there a way to see if it will work or does anyone know? I got on a rover parts site and they both have the same part numbers but…. Any help would be greatly appreciated!!! |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Have you flushed the GB and put a new filter and oil in?
Jayk69 appreciate the help! Yes I already tried all that. I ended up replacing the gear box. I’m now struggling with a code. P081C-62 electrical circuit diag, park switch. So I changed the transmission and now if I depress the brake pedal I can’t shift out of park if I don’t touch the brake pedal I can shift. Anyone have any ideas? Alldata says check wiring. Everything looks good but I’m going to start chasing wires and checking switches but I have a hard time believing a switch would fail during a trans swap. Also the trans needs flashed. Does that sound correct? Any hep would be appreciated!! Thanks!!! |
So I thought I’d update everyone. The fix was putting the valve body out of my original transmission into the replacement transmission. Seems pretty simple now but I had no idea these vehicles where so particular. Need less to say all is got except gearbox fault on the transfer case. I’ll be digging into that and possibly asking more silly questions. |
