![]() | Home > Maintenance & Mods (L322) > Windscreen protection and insect damage - Driving in Europe |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8557 ![]() ![]() ![]() |
Driving with a bigger gap between you and the car in front is the best way to avoid more chips, easier said than done on a lot of roads as someone usually fills the gap you have left... The other problem is the upright rake of the windscreen... nothing you can do about that...
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
For bugs I fat a large beach towel, lay across the windscreen and soak with a hose. Leave it on for an hour or 2 making sure it’s wet and then they just wipe off. |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 765 ![]() ![]() ![]() |
Insects wouldn't cause damage to a windscreen, if anything is just the residue left from hitting them at 80mph then baked on by the sun. I'm a European trucker so know exactly what it's like to keep cleaning the windscreen. France have the right idea supplying 'raquelettes' at fuel pumps to clear the flies away, although very good at doing it, it doesn't get rid of the dead residue. I use a green scouring pad to go over my truck windscreen and does a great job indeed in taking away the insect residue. It doesn't even scratch it either, just make sure it's nice and wet and job done. Another good product that i use is fly-away from Chrome products, you'll get this from most services in the UK. Just spray it on windscreen whilst you fill up, then use sponge or the raquelette at French services and clears the screen from dead bugs in no time. |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
Thank you all for your different ideas / methods - All sound worth a try, so a few good options to experiment with.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
I always use an old stocking, (not mine..) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
I'm in the south of France at the moment and yesterday we had 40 degree weather...as you can expect we had many foreign body's on the windscreen... McDonald's wipes and water cleaned pretty well... ... - .- -.
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
put 30 ml of ipa in spray bottle fill with pure water or filter water in a 500ml sprayer very good for ripping the guts off also use for cleaning the rest of the windows you will not use anything else use microfiber cloths .
I suppose that's one way of dealing with the French ![]() ![]() |
Will give it a whirl oggy ![]() ![]() |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 744 ![]() ![]() ![]() |
Hi AJA, apologies I did say I would ask the guys who did my PPF about a product called ClearPlex which is a PPF for windscreens - it might be worth a look. Im back at REEP next friday so will ask about its suitability for a heated RR screen.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1560 ![]() ![]() |
I assume you mean methylated spirits - unless you blokes in the UK can get a drinkable version of metho. ![]() 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
I couldn't spell either so it's spell checks fault...... |
gtechniq that do ceramic coatings do a g5 g4 max repellency glass kit which is a coating you put on and it states easy bug cleaning new vehicle purchase
