Home > Technical (L322) > Air con intermittent - is this the PCV issue? 4.4TDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Sounds like it. Does it takes ages to go cold too?
19th Jun 2022 8:39am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
From a cold start up, the car takes about 5-10 minutes for the air con to kick in. It remains working so long as I'm driving at speed.
19th Jun 2022 9:39am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 |
I thought it was called the RCV....
19th Jun 2022 10:01am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It could also be a low refrigerant charge. It'd be worth getting it recovered to check the charge weight against spec.before jumping in and replacing the RCV. |
19th Jun 2022 10:19am |
