Home > Maintenance & Mods (L322) > Passenger Cam cover replacement |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
Quite a few empty connectors around, you are right, it is for something you don't have... just ignore it, good luck with the rocker cover... Pete
14th Jun 2022 5:59pm |
oilmagnet477 Member Since: 14 Jun 2022 Location: Norfolk Posts: 4 |
Thanks for you feedback, reassuring to have it confirmed - I have managed to get the 'plug' out so the female connector is attached to the main loom (and replaced). It is clearly a blanking plug!
14th Jun 2022 9:34pm |
Hi again,
15th Jun 2022 12:55pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
I believe that goes to the vacuum unit on the rear of the cam cover that controls the inlet flap things, I’ve just done my cam cover seals today and looks familiar 2009 (2010 MY) 5.0 Supercharged Autobiography
18th Jun 2022 8:02pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I would be interested to hear any tips on doing the seals, my passenger side seal has been on the to-do list for a few months now but I keep putting it off as too hard for a small leak. I have got parts ready but need some inspiration 2007 TDV8 VSE
19th Jun 2022 1:09am |
Passenger side is the easiest, assuming you drive on the same side as us, just be careful and take your time and double check everything, plugs as there are a lot of them, be careful with the vacuum lines as they get brittle and easy to break.
19th Jun 2022 12:20pm |
Thanks for that, I only need to do the N/S, the O/S was done by the previous owner, it's noted on the invoice that the nearside had a small leak and they re-torqued the bolts and advised to monitor but did not change the gasket. Did your injectors come out easily without a puller? 2007 TDV8 VSE
19th Jun 2022 12:57pm |
No, I was fortunate that they all came out, 1 was a bit stubborn but after an hour it came out 2009 (2010 MY) 5.0 Supercharged Autobiography
19th Jun 2022 5:56pm |
