Home > Technical (L405) > Camshaft position sensor seals/gaskets/o-rings |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
While having my alternator replaced due to a significant leak from the RH timing chain cover, the mechanic found the camshaft position sensor seals and the variable timing solenoid actuator seals leaking as well.
18th Jun 2022 3:35pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Your mechanic should have a stock of O rings, one should fit that... Pete
18th Jun 2022 3:50pm |
Don't think you will have much luck on here, most have fatties powered by the devils brew... very few petrols.... Pete
18th Jun 2022 4:01pm |
I know. Worth a shot though. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
18th Jun 2022 5:04pm |
So I pulled a sensor out, the RH upper is the easiest and took it to my local auto parts store to see if I could match the o-ring. They didn’t have a new sensor in stock to compare too.
18th Jun 2022 9:03pm |
