Home > Technical (L322) > OBD Port Cover
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
OBD Port Cover
My OBD port cover has gone awol. A few for sale on Ebay, but is there something missing from this one? Exposed contacts showing, or is it just a spring clip?
 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #625633 7th Mar 2022 6:35pm
Googs
Australia
G’day RR2B, did you ever find out what was that weird hole in your obd2 port flap?
Post #632270 19th May 2022 7:59pm
RR2B
Hi Googs, no I’m still flapless. Didn’t risk that dodgy looking EBay offering. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #632284 19th May 2022 9:04pm
Googs
Australia
Yeah can’t blame you for that!
Did you work out what the hole thingy was about?
Post #632295 19th May 2022 11:42pm
Googs
Australia
So I took a photo or two of the obd2 port door on my L322 today….guess what I found, oh no same same
Post #632412 21st May 2022 7:47am
RR2B
Ah, so maybe the Ebay offering wasn't so dodgy after all! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #634900 18th Jun 2022 8:22am
Googs
Australia
Nah, looks like a stock unit!
Be interesting to see a few more, so any one out there with a photo or two?
Post #634914 18th Jun 2022 10:15am
Merchy
Regarding the OP, and pics, I looked at mine, it is exactly the same. The metal insert is not a spring clip, as it has three metal probes that go into three of the holes / contacts used when plugging in a reader.
Why are there three pins that make contact, and obviously ( to my mind ) make a circuit?
I realise that I have now made the water even murkier, as I have no idea as to the reason behind these pins, hopefully there will be someone with more intelligence than me who can explain why Confused Big Cry
Post #634970 18th Jun 2022 8:30pm
Range Rover L322
The hole with the three pins on the driver compartment OBD (OBD1) port cover is not used for us on the L322.
Some cars have a second OBD (OBD2) connector in the engine bay, this is often a round 20-pin connector. When these are in use there are pins in the OBD1 connector to "complete" a bus circuit for diagnostics when the factory diagnostic tool is connected to OBD2
Therefore, the OBD1 must be closed when using OBD2.
I am not sure if it is a Ford or BMW part, but I know for example Minis have 2x OBD ports. This part was originally manufactured for something else and used on the L322, but serves no practical or functional purpose for us. I put a new cover on which is permanently pinned open as I use an extension lead with a switch going through the lower dash and down under the drivers seat to my IIDtool. {side note - the switch is vital}.
Hope that helps....
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #635029 19th Jun 2022 9:46pm
Merchy
Range Rover L322 - Thanks for the info, that makes sense,I did think about the cover pins completing a circuit, but have never had a car with a second port in the engine bay. Cheers Thumbs Up
Post #635034 20th Jun 2022 7:13am
