Home > Technical (L322) > Help me with my vibrations!
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
So, some context and back story.
The car has always had a bit of a vibration like the wheels needing balanced. Found out I had a slow puncture in the OSR so replaced both the back tyres. This helped the vibration to a degree but it was still there.
Front brakes were squeeking and generally looked a bit crap so had them replaced (discs and pads). Figured if the discs were a bit misshapen this would help. Vibration still there.
Found the OSR CVD had no oil in it - had both rear CVD shocks replaced, still have the vibration.
Replaced both front tyres to match the rears. Vibration still there.
Discovered the NSR disc was a lot hotter than the OSR; had that checked out and the garage freed up the slider and made sure all was okay. Vibration still there.
Car has been on a hunter 4 wheel alignment system and only the fronts needed very minor adjustment.
Vibration still present.
It happens after 70 all the way through to about 90ish however it is more prominent when you're slowing down (just letting off the throttle) and particularly at around 75mph.
When it happens, it's mainly felt in your backside/seat rather than the steering wheel but when slowing down and you get to that 75mph point, it's quite obvious through the steering wheel.
What's my next option? I've thrown a few K at this now (though a lot of that was routine/preventative anyway) so I want my next spend to be specifically for this issue.
The specialist I use doesn't really know what would be causing it at this point. He is of the opinion that the centre prop bearing is fine.
I wonder if I should try and find someone local to swap wheels with, temporarily, in case something is buckled, maybe?
Help? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #634841 17th Jun 2022 2:46pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
The sliders are not really the problem on the rear callipers. It's the piston that gets seized.
Might be worth checking to see if your discs are still getting hot. Check out my project (link below) as I had a seized calliper too, it's really common. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #634842 17th Jun 2022 2:52pm
MartinD
Yeah I've checked them and they're nowhere near as hot as it was - both the rears are now the same 'warm' temperature. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #634843 17th Jun 2022 2:55pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Have you had the wheels checked in case one of them is slightly buckled ?
Post #634854 17th Jun 2022 5:20pm
MartinD
Well, yes and no. They've been balanced and the tyres changed twice now and noone has said there's a problem.
Was perhaps thinking of swapping with someone else to try there's and see if the problem persists for that reason as I don't think there's any other way to determine that really? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #634856 17th Jun 2022 5:22pm
I take it you have had all the suspension arms and bushes checked, the alignment will not necessarily pick this up if you have issues.. Pete
Post #634866 17th Jun 2022 6:22pm
MartinD
It has been at the specialist 3 or 4 times over the past month for various work and every time the vibration has been talked about.
They've told me they can't see anything untoward anywhere and at this point don't know what to suggest unless we start throwing part at it. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #634871 17th Jun 2022 6:43pm
JayGee
This must be very frustrating to say the least. I can only offer a few suggestions;
Next time you decelerate switch it into N and see what happens.
Give each CV joint (inner and outer) a test by trying to move the drive shaft around.
A seized brake callipers that causes overheating can warp a disk which would normally just cause vibration under braking but it’s worth investigating nonetheless. 2012 TDV8 Vogue (L322)
Post #634876 17th Jun 2022 7:10pm
MartinD
JayGee - I believe that has all been done by the specialist as he was aware of the issue every time I went in. He stated he couldn't find any issues that would cause the vibration.
I have no reason to doubt him either; he certainly seems to know his stuff and a few on here recommend him, too.
Normally it wouldn't bother me too much but I'm driving to Spain in 2 weeks and sitting at 70-85 for 1500 miles with a constant vibration is going to totally ruin the luxury drive. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #634877 17th Jun 2022 7:18pm
Mikey
Swap wheels front to back, see if it moves to the steering axle
I had a vibration on an old car of mine. Balanced up fine every time. Eventually took the cover off the balancer and watched the tyre spin, had a small flat spot in the centre of the tread that wasn't visible unless the wheel was rotating quickly Thumbs Up
Post #634886 17th Jun 2022 9:39pm
MartinD
Thanks Mikey - was hoping you'd pop up! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #634887 17th Jun 2022 9:46pm
JayGee
Get the wheels on a hunter road force machine as this tests for out of round issues 2012 TDV8 Vogue (L322)
Post #634891 18th Jun 2022 5:37am
MartinD
No idea where I'd find one of them round here! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #634950 18th Jun 2022 4:53pm
batfink
Pro-Grip in Falkirk have Hunter wheel alignment so they might have a hunter wheel balancer.
Failing that they also have an "Intelligent Vibration Analyser", which is supposed to ID where any vibrations are coming from.
https://www.pro-grip.co.uk/diagnostics/
Post #634953 18th Jun 2022 5:30pm
MartinD
Ever used them?
Might be my only option.
Thinking I'll take it to Kwik fit and swap the wheels around to see what, if any, difference it makes. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #634954 18th Jun 2022 5:39pm
