Home > Technical (L322) > Interesting question... |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1695 |
HI All, - I wonder if I could ask for your advice here. I've bought a Light Control Module to upgrade my lights/wipers to auto and it arrived all looking good. I've since had an email from the seller with the following.
11th May 2011 7:50pm |
Will a 2007 work in your car? I would double check 100%.
11th May 2011 7:59pm |
I was told it is from an 07 FFRR so should not need any coding and should work straight off.
11th May 2011 8:13pm |
RE Stored Mileage - it is possible to "correct" the stored mileage in the LCM
11th May 2011 8:16pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Yes that part number confirms that it is from an 07 onwards Range Rover, in theory you should be able to just swap the unit over and off you go, but if your vehicle has options enabled that the 07 vehicle didnt you will need the unit programmed to enable those features e.g. TPMS, engine type, follow me home settings etc... The LCM stores a lot of personalised settings that can be enabled by the request of the customer at the dealers Matt |
11th May 2011 8:21pm |
Or Rover All Coms |
11th May 2011 8:24pm |
Sorry i mad a mistake about the milage, forgot i was writing about the LCM, its the instrument cluster you can't modify easily (the only way to modify it is to remove the EEPROM memory PIC from inside the cluster and replace it with a new chip) You are correct you can 'modify' the LCM milage using PA Soft (which is designed for BMW's) Matt |
11th May 2011 8:26pm |
Or using my Faultmate Extreme lol I was just letting comports know that he may need features re-enabling after he has fitted it - dealer, all comms, or faultmate can all do the same job. I was just telling him that the personalised options enabled on his vehicle will have been enabled by the initial customers request. matt |
11th May 2011 8:33pm |
So are you all suggesting that I should just swap it out for another one. what possible issues could it cause me. I suspect I would have to get a new part number and confirm the details for it first? Ash
11th May 2011 9:25pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
id ask him for the part numbers for his new one and just check here first to see if that to will be ok for you........ what parts are needed guys for this upgrade as i miss not having this "RANGEISM WILL NOT BE TOLERATED"
11th May 2011 10:57pm |
Personally if the unit you have is working then i would keep that one and just say you have already fitted it, as you dont know what rubbish he may send you in return. He can fit the unit that he has in his car as basically from 05 onwards they are all the same upto 2010 02-05 is quite different and cant be fitted to later models (ie does not have auto lights for example, among other things) If the milage is out tell him about PA Soft which can sort that problem out Matt |
11th May 2011 11:00pm |
