Home > Technical (L405) > flashing shift (D) indicator, then knocks out of gear
simplyash
United Kingdom 2014 Range Rover Vogue SE SDV8 Scotia Grey
flashing shift (D) indicator, then knocks out of gear *** anyone have the same problem??? ****
*** anyone have the same problem??? **** out of nowhere the D/drive light started flashing, then knocks it out of gear, Took it out of gear to neutral, the nuetral light comes on but the D light is still flashing. Turned the engine off, started it back up and everything is back to normal. Normal for a month, then it happened again. Turned off the engine off, restarted and everything is back to normal. The car shifts / drives like normal all the time. Any idea what is could be, thanks
Post #495842 17th Nov 2018 10:30pm
Possibly a sticking selector mechanism.
Try getting under it with a can of spray grease👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #495862 18th Nov 2018 10:13am
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Have you had an immobiliser fitted? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #495875 18th Nov 2018 11:32am
simplyash
Hi, no immobiliser fitted, forgot to mention, the 1st time it happened, I restarted the car and the red triangle came on, restricted preformance, turned the car off for 10 minutes and and restarted worked fine, also called out the AA, who could not find a fault code.
Post #495878 18th Nov 2018 11:39am
Goodfella
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
Re: flashing shift (D) indicator, then knocks out of gear
I had this exact same issue today, did you ever find out what it was?
(I realise this is an old thread but worth a try..)
Post #634610 14th Jun 2022 3:35pm
Goodfella
Car was running strange again today (lumpy I suppose is the best way to put it..) so into the garage I use it went.
Just to help anyone that sees this..
Fault code has thrown up the EGR so looking at having this replaced then hoping that’s it!
Post #634698 15th Jun 2022 2:47pm
