![]() | Home > Wheels & Tyres > Spare Wheel |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
For the cost, I'd be trying to get hold of a proper matching spare - or even a part worn tyre in a slightly larger size with the same circumference.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
Keeping that as a spare wouldn't worry me at all tbh |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8352 ![]() ![]() ![]() |
IMHO that will be no bother at all.... |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 105 ![]() ![]() ![]() |
Thanks for your replies, I will in the fullness of time invest in a new 20" rim however as the consensus is it'll be okay for now I can concentrate on slightly more important purchases (in no particular order suspension parts and the wife's birthday |
Full size spare is much better IME. Even if the size of the space saver is the same you can't drive far or long on it which means your journey is interrupted by a trip to the nearest tyre fitter who likley won't have the same model tyre to match the one you want so you have to hope they have a cheap replacement to get you on your way which you will have to replace when you get time. All a lot of time and £££. With a same size matching tyre you just change it and you are on your way. 2012 TDV8 Vogue (L322) |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
+1 for full size spare.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 ![]() ![]() ![]() |
Yes I've just co opted one of my Turbines to be a full size spare (I still have 4 left) obviously It'll get me home at full speed regardless of distance but I'll still need to swap it because it won't match the rest of the wheels. Geoff |
The OP wasn't asking about space savers, he is using an 18" full size wheel as a spare when he has 20" wheels on the fatty.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3142 ![]() ![]() ![]() |
The tyres that are on your 20” wheels aren’t the original size either.
