Home > Technical (L322) > Air susp issue after new rear bags
322BLL
Estonia
It’s a kit. If you search you will find it immediately. I ordered it from ebay.
Compressor is (factory) new.
I didn’t change f/r leveling valve solenoids and even put the old valve block back. I almost ordered new for rear.. Gap tool helped me out with lives values and pointed to right direction.
New compressor raised the car and filled the air tank with minutes.
Post #634141 9th Jun 2022 11:58am
Googs....Chance are the old compressor had to work too hard and wore out the new piston seal, don't know how many times you can rebuild them but the overhaul kits work great on the few I have done...
322BLL...All that you have replaced now should make it great for years to come... Thumbs Up Pete
Post #634150 9th Jun 2022 1:41pm
Googs
Australia
Thx Pete, I’m gunna get a kit from eBay any give it a go after all we are not paying sheep stations for em!
Post #634198 9th Jun 2022 8:05pm
322BLL
Estonia
Good idea to start with kit(would do the same before buying new compressor) since much cheaper and might be all you need. From what I found I believe a compressor is good for 200-250k km. Can’t keep changing only the piston ring forever Laughing
Post #634305 11th Jun 2022 8:18am
