Home > Technical (L322) > Hesitation, Red Restricted Perf, hardly runs, codes…4.4 TD
Page 1 of 3 123>
Avityesboy
Hi all, any help greatly appreciated as I’m not sure where to start, I have a pretty good general mechanical knowledge but not overly technical so bear with me…
Ok so I purchased my RR a few months back with 177k miles on her for a decent price. I proceeded to change the oil and filters (except fuel filter, it’s a genuine LR one changed 30k ago). I had the gearbox mega flushed by bodsy.
I’ve covered 2.5k miles in at and it had been completely amazing engine wise not missing a beat, started and ran beautifully.
I don’t push her hard at all.
A couple days ago I pulled out of a junction and got up to national limit, there was a moment of power loss followed a few seconds later with the Red RP light…
The revs were getting less and less but I managed to limp it to my customers house where I was headed…
I tried the normal switch off and switch back on, no luck still running very rough and lumpy hardly revving above 800, occasionally stalling.
I left it for a few hours, removed and cleaned the MAFS and MAP sensor which didn’t look dirty anyhow. Again tried and still the same. Unplugged mafs and still the same.
At this point it it was just the RED RP light, I waited until I’d finished my work and called Green flag for recovery as didn’t run well enough to even move now….
I then noticed now the warning light was accompanied by a Red DPF full visit dealer light which wasn’t on previously…
I’ve had no issues whatsoever with anything DPF related, no yellow warning etc etc…just seems strange it’s came up straight away Red? I’m wondering if that’s actually the fault or something has gone causing it to think that as it didn’t say DPF straight away when it was running terrible? I code read and there are 2 codes that won’t clear…P2463 DPF restriction soot accumulation and P040D EGR temp sensor A….
Now by assuming those 2 faults are causing these issues it’s pretty straight forward I guess, change the sensor and get the DPF cleaned off the car, put it back together and away she purrs….
I’m not entirely convinced of that though due to the fact it barely runs now, will start for a couple seconds really lumpy then stall….
I’ve a feeling there’s something underlying that’s caused the issue? It really seems like a fuel starvation problem but unsure…
Where to start guys and gals? Thanks in advance for any advice..
Post #634105 9th Jun 2022 7:21am
Dolphinboy
do a search on here for DPF. there's loads of info. it is unlikely your DPF is full or needs cleaning or removing. It may be sooted up by an air leak. In. my case it was the inlet manifold cracking, although most other's fault was caused by leaking pipes to the plenum.
Get a HIGH pressure smoke test done first.
Post #634108 9th Jun 2022 7:31am
Avityesboy
Hi, trouble is it won’t run now for more than a couple of seconds and most of these diagnostics require it to at least run…hmmm
Post #634112 9th Jun 2022 7:47am
Avityesboy
But I will check the manifolds as that’s free and easy as a first step I guess..
Post #634113 9th Jun 2022 7:48am
GraemeS
Check for leaks in the form of oily residue from the 4 connecting hoses between the air inlet manifold and the inlet manifolds.
Post #634117 9th Jun 2022 8:06am
Avityesboy
Quick update, had a look as much as I could see at the manifolds and hoses and they are all fine…
Still the same 2 codes too…
I took a video but can’t work out how to post it, literally starts runs really rough and dies in a couple of seconds…so still figuring what’s the best way to proceed…
Post #634190 9th Jun 2022 5:29pm
Phoenix
As mentioned above, a high pressure smoke test needs to be done, it'll either rule out a charge air leak or confirm it. Just because there are no witness marks doesn't mean you don't have a leak that's has only just started. The DPF full DTC can be set when there is a lack of boost pressure compared to exhaust pressure (excessive back pressure), unfortunately, the ECM can't tell which of the sensor readings is correct so sets a 'protect the environment' DTC.
Post #634192 9th Jun 2022 5:40pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
you can ignore the P040D code this will not be related. you need to get a tool to measure how much soot is in the DPF. as mentioned you need to find the cause for the DPF to fill up. if you have a IID tool also look to see when the last re-gen happened or the last attempt.
I have a LRii Icarsoft and it will show me that information but have never had to force a re-gen. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #634197 9th Jun 2022 6:30pm
Avityesboy
How is the smoke test carried out? Is that something I can do myself? Or do I need to get someone in to do it as the car won’t run? Thanks.
Post #634218 9th Jun 2022 9:32pm
Avityesboy
I’ll have to see if my mates Snap on solus will read that, I know it could at least do isolated component tests too…
Post #634219 9th Jun 2022 9:35pm
Phoenix
A decent smoke tester will cost ~£300, find someone mobile that can do a 'high pressure' smoke test - high is not 100psi, more like 20-30psi, much more and you'll/they'll be damaging stuff.
For now, ignore any downstream DTC's, concentrate on the induction side and prove that leak-free before moving to the exhaust side. You'll just end up pecking away like a Hen without really getting anywhere, the key to effective diagnosis is to lose any confirmation bias and progress methodically - just because one part tests OK doesn't mean wasted time - you've just eliminated it as a possible cause.
Post #634220 9th Jun 2022 9:38pm
Avityesboy
I think what I’m going to do is get her recovered to my local specialist (Mark Smith) in Bicester for them to take a look at and diagnose. Thanks for your help so far I’ll keep you updated.
Post #634232 10th Jun 2022 6:14am
DrRob
You've chosen the best route. If you're not au fait with these things best take it to someone who knows their Censored Thumbs Up
Is this you by any chance?
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #634237 10th Jun 2022 6:59am
Avityesboy
That’s not me no but I’ve commented on his post and that’s what reminded me of Mark smith lol, I wish mine still drove and was an amber warning lol
Post #634254 10th Jun 2022 11:42am
Avityesboy
Taken to Mark Smiths specialist for diagnosis.
Post #634482 12th Jun 2022 10:08pm
Page 1 of 3 123>
