Home > Maintenance & Mods (L322) > Service Details
Bigbangman
United Kingdom 2006 Range Rover Vogue SE TDV8 Java Black
Service Details
Hi all,
I'm a bit confused over the service scheduled on my 2006 4.2, its now due, 12 months ago it had an Inspection 2, i assume now that its an Inspection 1 as they seem to alternate, mileage is just over 25k
Is this right?
If so, can anyone point me to where i can see whats done under the Inspection service 1 v 2, also what am i likely to have to pay at main dealer for this.
Big Cry It also needs its MOT but I have a non working rear washer so i may or may not mention this to them, assuming it must be the non-return valve although i don't think there's any pump noise when activated so could be something else!!!!
Thanks If its not broke now it soon will !!!
Post #63420 11th May 2011 12:37pm
No, it will now only need an oil service.This is good news as its cheaper.
The intervals go:
Oil service
Insp1
Oil Service Insp2...generally anyway.
When you turn the ignition on and the service indicator tells you it needs a service, it will then say Inspection if one is required. Discovery 4 HSE
Post #63422 11th May 2011 12:50pm
Worst case scenario with the rear washer pump and motor is it needs replacement.
I had to do this once, here's a write up, you can do it yourself easily (i'm not a mechanic)
http://www.fullfatrr.com/forum/topic884.html Discovery 4 HSE
Post #63423 11th May 2011 12:51pm
Mostly they just do a lot of "Inspecting" and charge you for it Neutral
Post #63426 11th May 2011 12:55pm
Bigbangman
Thanks for the info, dash just says Inspection 5/11 so i take it that as the last one was an oil service inspection 2 this will be a cheaper oil service inspection 1.
I checked the washer and the pumps is working but no water out of the back or leaks appearing on the ground; its got an MOT tomorrow so I'll just keeo my head low and hope they let it go.
Cheers If its not broke now it soon will !!!
Post #63471 11th May 2011 6:16pm
