Home > Technical (L322) > Hesitation of gear change
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Thanks for the info. Good pics of how to do it on your other topic. As it's being seviced , I'll ask if they change the fuel filter as part of it (probably not I assume).
Cheers
Steve Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #6327 2nd Jul 2009 10:29pm
Mine looked like it had never been replaced, despite it being part of the service schedule.
If I were doing it again I'd advocate replacing the 2 jubilee clips for conventional slotted screwdriver type, rather than the Land Rover special tool version on the car. Makes it harder to tighten them up again. Stupid decision by LR if you ask me. Discovery 4 HSE
Post #6330 3rd Jul 2009 3:12pm
RRVSE
I'll check to see if it is covered then as this isn't a cheap service and I don't want to be paying them even more for 'customer requested extras'!
Thanks Steve
Post #6338 4th Jul 2009 11:22pm
If they are not going to replace it, it really is a dead simple task, you only need a screwdriver, pair of pliers and torx bit.
With the filter being £10 only and 2 new jubilee clips being a few pence, why not do it anyway? I was quite surprised just how much filth was in the fuel. Discovery 4 HSE
Post #6339 5th Jul 2009 3:18pm
nbunney
Do you have to fill the filter or does the system clear air out it's self?
Ta
Nigel
Post #6342 5th Jul 2009 5:46pm
I just put the new one in and let it sort itself, there is nothing in the workshop manual either about manually filling it up.
When you look at the official service sheets, I am amazed they don't replace the air filter on every service too, seems barmy to me. Discovery 4 HSE
Post #6344 6th Jul 2009 8:32am
nbunney
Agree with you there.
It's not as if it is hard and they are not that expensive.
Best to fit a K&N and that's it.
Post #6345 6th Jul 2009 9:16am
RRVSE
Yep, reckon I'll get it done one way or the other then.
Thanks Steve
Post #6358 6th Jul 2009 11:05pm
Larry
England 2006 Range Rover SE Td6 Java Black
Well, I finally know what the problem is - Gearbox is completely shot - only 3 weeks outside the extended warranty.
Dealer don't want to know despite them having misdiagnosed the problem throughout the last 12 months. They reckon that there are a lot of faults that could have caused the same symptoms so it's only happened in the last couple of weeks - Censored !
Anyway, they want £3500 to replace the transmission. Lets just say that it's very unlikely that they'll get another penny of my money.
I have done a lot of digging and this fault is the Torque Converter breaking up over time and letting debris get into the oil, which in turn destroys the clutch(es).
So I'm posting this to act as a warning for others, and by way of a thankyou to some of you on this forum for good advice. If your car starts to judder when accelerating - especially at about 30 - 45 mph (even if just for a few seconds) and it is still under warranty, drive straight to the dealer, hand them the keys and tell them you don't want to see the car again until they fit a new gearbox and change the oil cooler (to ensure there is no trace of swarf left in the oil system)
This is the last straw for me. After 15 years of Land Rover ownership and a lifetime of loving them, its Good bye Range Rover . The most appallingly unreliable car I have ever owned.
PS. If you're tempted to service or buy your next Land Rover from a main dealer in the general Derby area, look further. Incompetence may well be part of the training there.
Post #8428 15th Nov 2009 1:46am
nbunney
OMG.
That's not very good from your stealer.
Larry have you gone to LR / another stealer to see if they will help?
As you say the gearbox has not gone bang in the last 3 weeks.
Hope you manage to sort it, without too much expense.
Post #8429 15th Nov 2009 7:51am
RRVSE
Don't they operate the goodwill gesture system like Renault do , in that , as it's just out of warranty, they put a percentage towards the cost? Could be worth checking with another dealer. I crashed the gearbox in my other car and ended up dealing directly with ZF Uk who had the parts shipped from the U.S. That gearbox would have been @£8,500 to replace at a main dealer (if they could get one) but the parts cost me around £2,400 shipped and I got a mechanical engineer to strip and rebuilt the box for a fraction of what a main dealer would have charged (not that they would be able to do that task anyway, they would just replace it). Steve
Post #8430 15th Nov 2009 9:03am
I've been told that if the car is under 6 years old you have some recourse via the Sale of Goods Act, whereby they should stump up most of the cash and you pay something towards it, even if its gone out of warranty.
I had a juddering issue, wouldn't get past 3,000rpm and struggled to reach 50mph, turns out it was the low pressure fuel pump. Replaced at a cost of £400 but its all fixed and I may be imagining things but the old girl seems a bit perkier. Discovery 4 HSE
Post #8434 15th Nov 2009 5:53pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Hi Larry,
Just picked up on this thread. Sad
You know by means of this thread, you have proof with dates and times regarding your gearbox? It's all logged.
Personally speaking, I would persue this to get the gearbox fixed by the dealer/Landrover under your extended warranty - regardless of it being out of date now.
You have a case that proves incompetence by said dealer to diagnose the fault and fix it during the time you were covered under the warranty, and I would speak to your local CAB about it.
It is what I would do.
Post #8447 15th Nov 2009 11:45pm
SteveMFr
Site Sponsor
Speaking as a lawyer - I would too!
While I can understand your frustration, you need to do something. If you sell the car with a knackered tranny, you'll take a large hit. Even if you have a cheapo rebuild job done an unload the car you'll take a hit (not to mention potentially setting yourself up for claims by your buyer if the tranny dies again a very short time later).
Don't get mad, get even!
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #8650 23rd Nov 2009 5:15pm
