Home > In Car Electronics (L405) > looking for a new amplifier, water got it -ck52-19c164-dn
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
hello
broken water roof tube has flooded my footwell
and killed my amplifier
did search eBay no luck, found one in the us for 2 ground Sad
if anyone know where to find one at decent price, pls message me
many thank's
meridian audio range rover amplifier ck52-19c164-dn 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #633734 5th Jun 2022 2:08pm
try and find a seller 'breaking' a FF on ebay.. ... - .- -.
Post #633740 5th Jun 2022 3:18pm
karba78
thks never thought this way
just sent a few requests, will see thks 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #633743 5th Jun 2022 3:32pm
Kot
ck52-19c164-dn
Put that in www.ebay.co.uk there is 1 for sale at £480 secondhand 2018 SE SDV8 4.4 Byron Blue
Post #633752 5th Jun 2022 5:00pm
karba78
thks tried
but it s not the same model
this is an LK and i am looking for a ck.. but thank's 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #633757 5th Jun 2022 8:19pm
Kot
https://www.facebook.com/837008793114507/p...509047231/
Try sending them a message? they had 1 in 2019 Rolling with laughter
Have you tried to get your amp repaired? might be worth investigating that angle 2018 SE SDV8 4.4 Byron Blue
Post #633790 6th Jun 2022 11:15am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
As I learnt when looking for a HVAC control panel, the code is often wrong in the title and/or description and/or photo as sellers re-use title/description/photos so worth looking at all variations and enquiring, particularly if there aren't many to ask about. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #633793 6th Jun 2022 11:42am
karba78
karba78 wrote:
thks tried
here are some pics if it helps
1999 TD5 Defender
Post #633799 6th Jun 2022 12:45pm
karba78
Kot wrote:
https://www.facebook.com/837008793114507/posts/ck52-19c164-dh-range-rover-vogue/1277681509047231/
Hello good idea will try that if i dont find one, but afraid it would cost me more than a second hand, plus need to find a guy in france that would know how to fix those... 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #633800 6th Jun 2022 12:48pm
Kot
Have you opened it up? maybe its just some internal fuse etc or needs drying out
Nothing lost having a look inside. Did it blow car fuses etc when it died? 2018 SE SDV8 4.4 Byron Blue
Post #633802 6th Jun 2022 2:29pm
Kot
Upgrade?
Just come across this on Utube, this guy replaced the amplifier with a Audison Bit DMI sound processor and a Audison F8.9 bit.
There are many parts to his project its worth considering at about £1200.
Its on a RRS but they have same system
Certainly worth searching utube for fixes etc
&list=PLj5pKllNcCED0PM5CvTsr3tavuNGqx82U&index=1
https://audiovisualworld.co.uk/audison-bit...essor.html
https://www.raysmith.co.uk/products/audiso...XEQAvD_BwE 2018 SE SDV8 4.4 Byron Blue
Post #633806 6th Jun 2022 3:12pm
karba78
Hello
i did indeed and let it dry in rice for 2 weeks.
but no luck.. 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #633828 6th Jun 2022 6:22pm
karba78
nice table from the powerfull uk guys here
if that helps anyone
https://docs.google.com/spreadsheets/d/e/2...U/pubhtml# 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #634121 9th Jun 2022 8:27am
manxaircrest
Isle Of Man 2013 Range Rover Vogue SE SDV8 Nara Bronze
Hi ... I have same issue with roof tube and now need same amplifier how did you resolve it in the end ??
Very best regards Brian
Post #645441 12th Oct 2022 1:35pm
karba78
was a nightmare
had to remove the ceiling, (which stops the car working because of the transceivers) and because the water damaged it. i had it redone...
then i took an empty 6mm tube (same as for lights) and redrilled a hole in the water cavity of the roof gutter.
screwed the 6mm tubed into it, and reconnected it to the drain.
took me three weeks.
if you rooftop is not damaged you can still access it through the rear light and aircon panel after removing them
but you have less space to work.
hope it helps... good luck; dont hesitate to ask or give me a call if needed 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #645447 12th Oct 2022 2:57pm
