Home > Maintenance & Mods (L322) > Rear disk horror
JayGee
Rear disk horror
Had put this job off for too long reasoning the rears don't do much work and there was still about 75% effective braking surface only to discover what was hiding on the other side. No trouble pulling them off the brake shoes as the rust was so bad. Used LR (Brembo Disks) and Delphi pads OS was easy to do and took my time to clean everything up. NS was a nightmare as the calliper was seized and needed a 12mm bolt and spreader plates to force it open. Also the inner slot in the carrier was narrower than the outer even after cleaning up the slot and plates and ended up having to file down the pad 'ear' to get a sliding fit. Previous pads were 'Brakefit' and the disks were OE. Going to replace both rear callipers and then do the fronts which have plenty of pad life and no rust but the disks are pretty worn and I'm not sure about having 'brakfit 'pads up front doing most of the work...... 2012 TDV8 Vogue (L322)
Post #633730 5th Jun 2022 1:04pm
kevinp
I always file the pads ears to make sure they are a nice sliding fit. I also tap the pad sliders into the caliper bracket with a punch to make sure they are in place snuggly. It's surprising how much further they will go.
Post #633736 5th Jun 2022 2:26pm
JayGee
Drove it round the block slowly for 5 mins and gently applying the brakes and when I got back the rear NS was very hot. New callipers ordered and car not moving until it's done. 2012 TDV8 Vogue (L322)
Post #633747 5th Jun 2022 4:31pm
JayGee
New callipers fitted ( easy job) Will road test later today to make sure my gravity bleed is OK. Pedal felt solid with the ignition off and servo drained of air so reckon i'ts OK. Will put the old calipers up in the for sale section if anyone wants to rebuild them. 2012 TDV8 Vogue (L322)
Post #634041 8th Jun 2022 12:36pm
