 | Click image to enlarge |
done the front brake pads on friday last when i was just testing brake pedal in and out of reverse notice reverse cam blank screen . so yet a new job to look at so yesterday . i tested with the meter the fuse no 12 5 am left side in boot area all good . took of tailgate panel pulled wires out white block black block for high level brake light and cam wire test live at the connecter all good so remove spoiler , and then removed cam easy job new camera fitted in 2015 wrote on tag on lead wire . but some one had cut the white block wires live and earth and re joined them twisting them together so out with the soldering iron and heat shrink . so i still went and opened up the camera and the pins 4 off was looking white so out with the ipa and a small brush cleaned the pins and board used a small amount of tiger seal and clamped together . after testing and working fine again just got to put it back tomorrow . i did notice a lot of white powder in side the spoiler alloy dust so cleaned out with air line and gave it half a litre of wax oil in around the cavity .
 | Click image to enlarge | new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
