Home > Technical (L322) > Fault codes 27 (P1174) and 35 (P1175) Intake Air System
pcourtney
just had a major service done on my 2004 Petrol V8, when I mean major, all new coolant pipes (2 ply quality oil resistant ones), new alloy rad, new thermostat, new battery, new gaskets, a lot of stuff, the reason I did this was because since covid started I have only done 4,000 miles, and the BMW engine did not seem to be as smooth as I had been used to in the past
so just got my car back, and everything is running very nicely, very smooth, gearbox is great, very good kick down acceleration is back, and pulls away from stop really well Smile
but I think I may have an air leak or two in the induction system
Group 11: Engine Bulletin Number: November 1997
SUBJECT: Intake Air System - Un-metered Air Leaks
MODEL: E39, E38, E31 with M62 engines
Situation: Check Engine Lamp is illuminated and fault codes 27 (P1174) and 35 (P1175), oxygen sensor control adaptation, are set in the Engine Control Module (DME).
Cause: Un-metered air leaks may occur in the following areas causing the above situation:
1. Intake manifold gaskets may be leaking.
2. Plug cap(s) and the vacuum hose for the fuel pressure regulator on the rear intake manifold cover (crankcase ventilation valve) may be torn or missing.
and saw this "Cheap Inlet Manifold Fix" - he really does seem to know what he is doing on M62 BMW engines https://www.meeknet.co.uk/e31/BMW_E31_840c...ak_Fix.htm
Post #633621 3rd Jun 2022 2:23pm
pcourtney
duplicate post
Post #633624 3rd Jun 2022 2:58pm
garyRR
To rule out head gasket, there's a cheap test kit on ebay for about £8. 2015 Range Rover Autobiography 4.4 SDV8
Post #633669 4th Jun 2022 9:32am
pcourtney
is it this one Gary ?
Blown Head Gasket Tester Kit Combustion Leak Block Fluid 15 tests Petrol/Diesel £9 quid
Post #633676 4th Jun 2022 12:18pm
garyRR
https://www.ebay.co.uk/itm/124375564723?mk...media=COPY
This one. 2015 Range Rover Autobiography 4.4 SDV8
Post #633677 4th Jun 2022 12:23pm
pcourtney
just to close this off, about 4 weeks ago I did the "Cheap Inlet Manifold Fix" and it fixed the problem
Post #638275 30th Jul 2022 6:57pm
