![]() | Home > Maintenance & Mods (L322) > £550-650 for a gearbox service? |
PraguePrado Member Since: 09 May 2022 Location: Paris Posts: 27 ![]() ![]() |
I don't mean for this to be a complete rant... just perhaps a reaction to the shock at the cost of basic service in the UK (I've been away a long time).
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
thing is , even if you are a novice at DIY car mechanics , you can do this job , so many videos to follow on YT , just take your time and be methodical , no need to get fleeced |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
There is a place in Kent that will do a mega flush for less than you have been quoted,
Does take a fair while longer than 1hr if done properly sir... |
Yes, this is true - another forum member suggested I contact Dartford Transmissions; they were prepared to do the megaflush and change all seals (not just the mechatronic, but drop the valve body and do the valve and bridge seals) for 600. Nowhere near Reading, but I would definitely have gone with him if he was open on Saturdays... Unfortunately coming in on Friday afternoon and no way for me to get to any of these places before they close on Friday. So, yet another reason for just checking the level myself and getting it to Prague (hopefully). Will definitely be getting RAC EU coverage! |
Yes, I was probably exaggerating a tad for the DIYer... but if you had a shop, I wouldn't expect this to take more than 60-90 minutes. This isn't a Sport - everything is easily accessible. Actually the quotes I received confirm that time: for example, one place says 1.7 hours labor, for which they want £145. That's ok. Where it goes off the rails is for the parts. They're quoting £310 for ten litres (won't take more than 7 for a change). ZF LG6 should be around 14 max, less for dealers. And they want £142 for the pan/filter. That's a a £45 part. And another £15 for the 21 pan bolts. That's £465 for parts that I can buy as a kit for £177.... I understand that businesses need to make a living, so as I said, I'm not really ranting. In the end, for those of us willing and able to get our hands dirty, the fact that these cars do need maintenance (expensive maintenance, if performed by others) means that this outstanding luxury vehicle is very affordable for us. |
A couple of points on your prices above, the labour rate and job time is about right, although you say the sump & filter is £45 - but what quality? you may be pricing Britpart and they're quoting ZF...
What area of the UK were you looking for a price? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
Place I had mine done 4 years ago, took oil changes in as the last job of the day, keep them draining over night to ensure that they get as much old oil out as possible, cost £350 then.
LT Member Since: 13 Mar 2017 Location: South West Posts: 403 ![]() ![]() ![]() |
I’m using this oil:
That's the stuff i've just done a double-flush on mine with, going to run it a month or so and do the valve block seals & filter, I fully expect the cooler and some of the contents to have drained somewhat plus I'll be tipping out any fluids from the valve block itself so it'll be nearer the dry fill quantity than the service quantity - which thinking about it, the service quantity never included a filter change, I'd guess that will increase the quantity required as the filter and tube will hold a fair bit. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
I've already replied to your previous post on this.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
You can do more damage by overfilling than underfilling, if it drives OK and all gears work and there are no leaks you should be fine to go...
