![]() | Home > Maintenance & Mods (L322) > Blower motor sensor |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
It could have been a bad connection which you corrected when you disturbed the connector.
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
Is the blower mower what cools the sensor ? Or something else? |
The sensor (or hedgehog) controls motor speed, hence the large heatsink.
The sensor or final stage resistor as it is called is cooled by the airflow into the ac / heating system when the blower motor is operating. If they fail they usually result in the blower motor operating at full speed only. |
robanzac Member Since: 07 Dec 2017 Location: New Zealand Posts: 15 ![]() ![]() |
I have had failing blower final stage resistors (or hedgehog or whatever you want to call it) really give me the run around.
I removed the sensor and naturally the heater didn’t work, so I’ve refitted the hedgehog sensor (wat a PITA) i did this by feel cause you cant see any hole where its supposed to go. haha Anyway the blower motor is going now but still throws a soft code! |
G’day Rob, sounds like you’ve had some fun n games with these prickly sensors aye? 😎🇦🇺 |
