Home > Maintenance & Mods (L322) > Tailgate Lock
supershuttle
Tailgate Lock
In my RR the half of the lock that is in the lower bit of the tailgate is loose - this causes the Tailgate Open warning to come on intermittently. I can't get a torx in to tighten the bolts, but at first glance it looks as if I remove the trim from the top edge I might get better access although I am not certain how to remove the fixings - I haven't tried in earnest yet.
If anyone has had similar and fixed is there anything I need to watch out for?
Thx Geoff
Post #62804 6th May 2011 7:46am
supershuttle
Actually it was simple, problem with having a good forum is it's too easy to ask Thumbs Up . Nipped out between rain showers and just did it, 5 mins, the only thing to watch for is getting the caps off the screws holding the trim in place if you ping them off with a screw driver they seem to travel faster and further than a speeding bullet. Geoff
Post #62806 6th May 2011 8:15am
job done..... Thumbs Up . ... - .- -.
Post #62807 6th May 2011 8:21am
JW911
When the lock comes loose again (it will), Loctite the torx screws back in. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #63329 10th May 2011 7:22pm
