Home > Maintenance & Mods (L405) > Steering vibration. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 734 |
Cheap discs? |
30th May 2022 5:37pm |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 219 |
They fitted TRW at £60 plus vat each. 2013 SDV8 4.4 SE Luxor.
30th May 2022 5:56pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
If you're only doing low mileage / short, low energy journeys then it may be a build up of corrosion on the discs, particularly on the inner face due to there being not enough brake use to scrub the discs clean & flat again before it is parked up awaiting the next lot of winter weather to corrode the discs even more. You'll find that there are patched where the pads have been that are not so bad, its transitioning between those parts of the discs and the more corroded bits that causes the steering wheel shimmy.
30th May 2022 6:23pm |
Phoenix, that makes good sense. My car is always garaged, and when I wash it, I always run it up and down the road to warm up the brakes. I can see your point, so it may improve if/when I undertake longer journeys. 2013 SDV8 4.4 SE Luxor.
30th May 2022 6:49pm |
One thing you can try is find a quiet road on a hill, drive down it at 12-15mph, apply HDC and then knock the transmission into neutral, you'll hear lots of ABS type noises whist the HDC does it's stuff, if it seems to be only lightly applying, use the cruise control + and - buttons to adjust the target speed for effect. Dependent on how long the hill is and how much surface corrosion there is, you may have to do this more than once.
30th May 2022 7:05pm |
Just to end with. My Indy did a full service today. He took all the discs off and cleaned them. Some had a rusty deposit. He thought this was caused by the vehicle being parked up too long. As Phoenix said. So all cleaned, no more vibration. 2013 SDV8 4.4 SE Luxor.
31st May 2022 7:55pm |
Good to know it was a simple fix. |
31st May 2022 7:59pm |
