Home > Maintenance & Mods (L405) > First oil change - please help a fool |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
https://www.toolstation.com/draper-expert-...tor/p51293
30th May 2022 9:47am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3824 |
I might have a go at this, however what do I do with the old engine oil? Geoff |
30th May 2022 9:54am |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Thank you @Baltic Blue - ordered. What do I put here then? |
30th May 2022 9:57am |
I'm pretty sure you can usually take it to your local tip. What do I put here then? |
30th May 2022 9:59am |
Geoff,
30th May 2022 10:03am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Don't forget to reset your service interval or the car's computer won't have a clue it's been done so oil dilution reading will continue to climb and cause warnings.
30th May 2022 10:16am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
The price for the oil pump is a bit strong.
30th May 2022 10:17am |
Smith and Allan oil OK? Geoff |
30th May 2022 11:38am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1194 |
Smith and Allan oils are excellent and they are very helpful if you have any questions.
30th May 2022 5:41pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I use one of these...
30th May 2022 8:04pm |
And yes, change the filter too....
30th May 2022 8:08pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1230 |
Oil reset L405 pop bonnet, leave driver door open, press full. Brake and accelerator pedals for 10 secs Oil filter 36mm socket required and 28nM torque. the 10L Draper is a dream and takes all your oil and fuel without having to empty and start again zero mess To read Oil level Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake). Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows! 2018 SE SDV8 4.4 Byron Blue |
30th May 2022 8:27pm |
Thanks all. Much appreciated.
31st May 2022 8:32am |
I have put several posts up showing oil change procedure for 4.4 tdV8 , mine is an L322, but your L405 is virtually identical.
31st May 2022 9:06am |
