![]() | Home > Technical (L322) > 2008 L322 HSE Not starting |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Did you ever fix this I have a similar issue starts second time round every time with the same code Current stable:
DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 59 ![]() ![]() ![]() |
Hi,
Fuel system related failed non return valve on pump was letting the fuel from the line seep back in but cranking a couple of times filled the line up Current stable:
Appreciate the reply, Dan!
To be honest different engine I know but I was lucky enough to have been donated a spare fuel pump (used but working) so I did it myself time consuming but not costly Current stable:
