Home > LPG > V8 petrol sounds like a diesel
Paulmeds
England 2002 Range Rover HSE 4.4 V8 Baltic Blue
Hi, I’ve had lpg on my 03 4.4 v8 for 5/6 yrs, it runs great no problem but over the last few years it’s started sounding like a diesel, can’t explain very well. It sounds the same on petrol as well. Any ideas as it regularly serviced at a Land Rover specialist and it’s never a problem they’ve mentioned. Any help or ideas would be appreciated.
Post #633141 28th May 2022 8:23pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Try running it on just petrol for a while. I belive that running on LPG only for a long time can cause upper cylinder head issues.
Post #633158 29th May 2022 9:07am
Paulmeds
Thanks for the reply and advice. I’ll see if I can afford to run it on petrol lol. I’d just like it to sound like a v8 should.is there anything else you I could get checked out.
Post #633166 29th May 2022 4:39pm
Dolphinboy
chain guides? Thy make it sound very rough when they go
Post #633170 29th May 2022 5:27pm
Gsxr1250dave
It's unlikely to be anything fuel related most likely mechanicle , it will be the M62 engine so you should be looking at
Chain guides
Timing chain
Timing chain tensioner
Vanos
Or even manifold gaskets
Post #633220 30th May 2022 10:58am
