Home > Technical (L322) > 4x4 info screen: red/white dash above each wheel
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
Hi
This is in conjunction with my current issues with regards to front suspension but I wanted to try clarify this specifically: is there any significance to the white dash above each wheel on the 4x4 info screen? There reason I ask is that whilst I’m having front suspension issues I’ve noticed that the front passenger wheel now indicates a flashing/intermittent ‘red’ dash above that wheel and the others remain solid ‘white’
Can anyone shed any light on what these are/may be indicating? Thanks in advance… Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #632772 24th May 2022 1:24pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
If it goes red it means the suspension is at the end of its travel / articulation in the direction indicated. In your case it’s saying I’m on the bump stop. Thumbs Up
Post #632773 24th May 2022 1:37pm
according to the owners manual the white lines [top and bottom] refer to the available wheel travel...
if theres a red/amber dash then , as Dave says, its at the end of its travel.. ... - .- -.
Post #632774 24th May 2022 1:44pm
grayst01
Thank you Chaps! Cheers, Steven.
Post #632785 24th May 2022 4:21pm
