Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 461 |
Hello Kot
23rd May 2022 7:28am |
Also the km until next service is still going up at the moment. SDV8 AB MY 2020
23rd May 2022 7:29am |
So it got to 100%. Active Regen started. It was running for about 10 minutes.
23rd May 2022 1:10pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1200 |
If you read page 1 of this thread you can see the first 2 active regions I captured. I believe you need to have engine up to temperature and above 80C oil temperature, I have seen AR's start at this temperature it could be lower. Have at least 1/4 tank of fuel, but I have seen AR's below this level but if you get an Amber alarm, threads on this site suggest it may not allow a AR start. I have seen AR above 42 mph, also there is a time element but usually its started after 20mins. Regarding passive, as long as your exhaust is above 250C it starts to passively burn off the soot, but dont forget you are producing more, the higher the exhaust (faster you go) more soot is burnt but more is produced I wouldn't worry about the 1 trigger not being on all the time. it concerned me early on but now accept exhaust temperature above 250+C it naturally occurs the number 1 trigger event is immaterial. 2018 SE SDV8 4.4 Byron Blue |
23rd May 2022 1:19pm |
Great you witnessed it, did you see the exhaust temps hit the 500C mark? Its proof you are in AR and when it drops below 300C proof the AR has stopped. AR (2) continues at 100% soot and when its completed the trigger drops to 0 and usually %soot at and below 12%. After a AR it shouldn't be showing 100% usually that means you have interrupted the AR process and its ready to try and Regen again next time conditions are met. 2018 SE SDV8 4.4 Byron Blue |
23rd May 2022 1:32pm |
Hello
23rd May 2022 2:17pm |
So I have just driven 180km. 140km on the Autobahn (100-170km/h)
23rd May 2022 5:43pm |
Go to Data Recording on the app
23rd May 2022 6:12pm |
The one from earlier where active Regen was triggered but didn’t seem to do anything, didn’t complete…
23rd May 2022 6:38pm |
The %soot (DPF soot Normalised Trigger for Regen) is not changing even though its clear you had an AR complete OK the pink line shows the trigger did operate to a 2 and ended successfully but the soot% (Red line)is still showing a false reading (100%).The pink line also shows you had correct passive Regen as well.
24th May 2022 8:50am |
I tried that. It is still 100%. I have contacted the developer to see what he thinks.
25th May 2022 1:22pm |
I am on about 650km since the last Regen. So I except it to happen soon. Looking at the km until next service is increasing again. Most of my next journey I can continue if it starts so I can go until it is completed.
2nd Jun 2022 5:50pm |
Did you try removing the obd2 device and seeing if that resets the soot value?
3rd Jun 2022 1:28pm |
I tried a few things. I got a new phone today so will set up the device on the new phone from scratch. About half the time at the moment I need to replug the device again when I start the car. The other times it is able to reconnect without me doing anything. No active regen today. SDV8 AB MY 2020
3rd Jun 2022 2:35pm |
