Home > Maintenance & Mods (L322) > Tdv8 4.4 egr valve
paulwlincs
Tdv8 4.4 egr valve
Hi guys , is there any information available on getting to the egr valve for my tdv8 4.4 ? . I can't find anything in the wiki . I got some useful help from dolphinboy regarding my p0486 code issue . I am keen to have a go .
How do I get a workshop manual , really appreciate your help , great site .
Post #563034 29th Jul 2020 9:54pm
DrRob
Workshop Manual is free to download in the Wiki Thumbs Up
4th one down in the workshop manual section at bottom of page. Keep scrolling Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #563053 30th Jul 2020 7:49am
paulwlincs
Thanks Dr Rob , I need stronger glasses Thumbs Up
Post #563096 30th Jul 2020 1:19pm
kevinp
Hi Paul. I'm always interested to know why people try to do a particular repair on their car. Why do you think there is something wrong with the egr? Any symptoms can help others sort there's out if you sort yours. Or am I being nosey. Lol.
Post #563196 31st Jul 2020 10:27am
GraemeS
Removing the EGR valve requires the oil cooler and filter housing to be removed, which once removed exposes unfiltered oil-ways. If any foreign material gets into those unfiltered oil-ways then the engine is at risk of being destroyed, so I suggest that you don't undertake the task of removing the oil cooler and EGR valve without good reason.
Post #563207 31st Jul 2020 11:03am
paulwlincs
Thank You for the questions regarding the egr issue . I was just wanting to know how to get to the egr valve to see if it was clogged if all else failed . I get restricted performance at completely random times usually when started when hot , never from cold only after being left for a while when out somewhere .
P0486 egr circuit b high is what I have and the usual p0404 exhaust temp a which I've had for 2 years without issue .
I had a local indie have a look without success , so it's going to have to go to my local JLR to sort out unless I can do something .
Dolphinboy has helped with some suggestions , I have always maintained my car's in the past , this one is a lot of engineering but still a car just bigger Laughing
Post #563258 31st Jul 2020 8:47pm
Dolphinboy
Have you done a HIGH pressure smoke test? That will highlight any leaks. My Pax side inlet manifold had a tiny crack that only became visible with the Hi pressure test. Also as your engine warms up, any tears/cracks/holes will expand making the RP more likely to occur.
Post #563260 31st Jul 2020 9:16pm
GGDR
9 of 10 times restricted performance on the 4.4TDV8 is caused by air system leaks.
Many many say they have checked but so many times those threads end with a leak eventually found and a happy outcome.
Unless that error code comes along exactly with restricted (you didn't say) I would be looking at the four donut hoses (sometimes splits are underside or within the clip area so you do have to check really well.
Next is the hose (and clip) that connects to the throttle body.
CSOV value too.
You will find loads on all the above using search.
If it's your EGR then do let us know, it is not common for faults there.
Good luck.
 Cheers, Greg
Post #563261 31st Jul 2020 9:20pm
GraemeS
You could try unplugging the connector on the EGR valve to see if the same code appears and refitting the connector may overcome a possible poor connection. However as EGR doesn't occur when the engine is cold it does seem that the valve may be sticky.
The valve's actuator can be removed from the body of the valve but perhaps this has other ramifications making such a task inappropriate whilst the valve is still fitted to the engine.
Post #563262 31st Jul 2020 9:24pm
paulwlincs
Ok , thanks for all the help , I will try a few thing's out .
The code only appears after restricted performance so I'm linking the 2 for now .
Post #563316 1st Aug 2020 7:52pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Paul, what was the outcome of this? Did you end up doing further troubleshooting or did it sort itself out?
I’m getting an EGR fault code but mine’s for EGR recirculation flow insufficient so am working on the assumption there’s either a blockage or the actuator is a little sticky. Would be great to get an update on your issue! 👍 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #632211 19th May 2022 8:01am
DrRob
Andy
I see you're in Surrey. If you need an LR specialist to take a look at it then call Ross at www.glenrands.co.uk and tell them I sent you.
Loan cars available Thumbs Up
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #632304 20th May 2022 7:30am
