Home > In Car Electronics (L322) > Replacing radio amplifier model number XGK000020
Paulmeds
England 2002 Range Rover HSE 4.4 V8 Baltic Blue
I need to replace/ repair my amplifier due to corrosion, water damage. Model number XQK000020, I found a few on eBay but some of the other numbers/ codes on the sticker are different to mine. Does this matter and what do they mean. Appreciate any help as I don’t want to buy one that won’t work correctly. Many thanks.
Post #632144 18th May 2022 5:15pm
Paulmeds
These are two I’ve found, could anyone please tell me if they are going to work as a replacement. Appreciate any help or advice.
Post #632177 18th May 2022 8:20pm
Paulmeds
Also maybe another silly question but do replacement amplifier need to be re programmed, and if so is this a dealer only job. Again appreciate any help or advice as no music is no fun.
Post #632561 22nd May 2022 5:02pm
Googs
Australia
Hey Paul, what year L322 do you have first up?
The 02-04 were the BMW series (Alpine) screen….the radio amp (tuner) and DSP if you have it….and from 05-09 (not sure about) were the logic7 system ( Ford i think) which are completely different operating system.
Someone will chime in if I’m not completely correct
I have an 02 L322 and boy oh boy have i had some dramas with the BMW series audio
Looking at those numbers it’s a model around 02-04 you have?
Post #633107 28th May 2022 6:06am
Paulmeds
Thanks for the reply but all sorted now. XQK000020 they’re all compatible. Got a used on from eBay, then just plug and play. Mines 03 hse with aftermarket kenwood unit. Works great now.
Post #633135 28th May 2022 4:19pm
mjdronfield
L30, shown on the label, is the BMW code for the RR. It only became L322 when they sold to Ford….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #633136 28th May 2022 5:07pm
