Home > In Car Electronics (L405) > Tomtom doesn't work with solar attenuating windscreen
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Hi,
So my Tomtom can't get a signal in my L405 that has a solar attenuating windscreen
I contacted Tomtom on their chat, to ask if there was a way of fixing it.... here is what they said !
(12:23:21 PM) Richard Lambert: Hi, I have a 2016 Range Rover with solar attenuating windscreen and I cannot get a GPS signal on my Tomtom, any suggestions on how I can get it to work please?
(12:25:56 PM) Patrick: Thank you for contacting TomTom. My name is Patrick. I will be glad to assist you today.
(12:26:10 PM) Richard Lambert: hi
(12:27:25 PM) Patrick: I understand the windscreen is blocking the GPS signal for the device. I will surely help you.
(12:28:10 PM) Patrick: In this case one of the workaround we could try is to remove the coating from the area where the device is located which will allow the GPS signal to penetrate the windscreen and reach device
(12:28:40 PM) Richard Lambert: I am not doing that as it would damage the windscreen
(12:30:28 PM) Patrick: I understand however of the coating is designed to block the GPS signal there is nothing much a device could do. Device needs a environment where the GPS signals are not blocked. You could check with the car dealer for alternative for the coating
(12:31:33 PM) Richard Lambert: I am not changing the windscreen! Do you not have an external GPS receiver ?
(12:32:31 PM) Patrick: I'm sorry there is no such external extension which could receive the GPS signal externally
(12:33:11 PM) Richard Lambert: OK, so you have been no help whatsoever. Bye
Fat lot of use they were !! 2016 AB SDV8 Barolo black
Post #632102 18th May 2022 11:41am
dhallworth
I believe there is a space right up beside the mirror that is free of the coating and is where they advise to place toll tags in the handbook.
Someone who knows more then me will no doubt be along shortly though Smile
Post #632112 18th May 2022 1:03pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
On that basis, it will be the black shaded area either side of the mirror housing. That’s where I have my Liber T tag.
Post #632137 18th May 2022 4:16pm
Can you not get a satnav mount that allows you to mount the Tom Tom on the front side window at the bottom front corner. Should work ok mounted there. Thumbs Up
Post #632138 18th May 2022 4:33pm
Anthonydi
I bought a GPS amplifier for my car as suffers the same issue when using my phone as a sat nav. Look on eBay for item ID eBay Item No. 114574964575 it works really well for me I stuck the receiver on the roof by the rear tailgate.
Post #632185 18th May 2022 10:03pm
