![]() | Home > Camping, Caravanning and Holidays > MPG check |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1198 ![]() ![]() ![]() |
I'm in the process of changing my 100amp lead-acid to 110amp lithium, also changing my 100watt solar to a 330watt solar, 1500watt inverter, mppt controller,
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
I’m lucky to see 19 when I’m towing a twin axle 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
I’ve been towing caravan’s for more years than I care to remember and my current SDV8 is by far the best on fuel whilst giving unbelievable grunt pulling a 2 ton van, but there’s a lot of things effect your consumption such as terrain IE if its hilly you’ll use more when windy and the coast goes up. I’ve had as high as 26 MPG on a flat calm day and as low as 17 on a hilly windy drive so I would put the overall average at around 22MPG while towing, not bad when you consider your pulling over 4.5 tons all up. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1260 ![]() ![]() ![]() |
I agree with Andy. 19mpg with 2 ton caravan. My previous caravan weighed 1.5 ton and the car did 26mpg!! I didn't expect such a big drop!! |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
One of the issues with the EV option is that I am yet to see a charging point that would allow you to charge without having to uncouple a trailer/caravan. This would then have to be secured to prevent it being taken whilst you await your fast/slow charge. On a 200 plus mile tow you are probably looking at two refills so more Afro and time consumed.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
I would love to get 24mpg when not towing ![]() ![]() |
