Home > Technical (L322) > HELP bad engine sound! 4.4 TDV8
Page 1 of 3 123>
Dactonx
2011 Range Rover Vogue 4.4 V8 Barolo Black
Hi all
Bought this car a few weeks ago and the engine has started to sound awful, the garage I got it from is telling me it’s supposed to sound like it, what do you guys think the issue is?
https://youtube.com/shorts/nrX3O6QxEWk?feature=share
Desperate for help! Thanks
Post #631602 14th May 2022 11:44am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I don’t know what it is, but it shouldn’t sound like that.
Anything to do with the viscous fan?
Post #631604 14th May 2022 12:12pm
GraemeS
Definitely not normal. Judging by the frequency it sounds as though it is occurring on a single cylinder.
Post #631606 14th May 2022 12:14pm
Dactonx
I checked the simple stuff isn’t related to the fan unfortunately.
Post #631608 14th May 2022 12:32pm
Merchy
The garage you bought it from sound like bunch of lying shysters Censored
Sounds very much like its coming from one cylinder. check your consumer rights, as I am damn sure you should be able to make them fix it or take the car back, especially if you bought it recently.
there was another recent thread involving consumer rights, some excellent advice was offered, someone with this knowledge should be along soon.
If they continue to deny that there is a fault on the car, then folks on here will want you to name and shame the garage involved.
Post #631609 14th May 2022 12:43pm
Cretosx
The thing is, i'm willing to name and shame if anything isn't done but I travelled 3 hours to collect the car so going back and forth isn't really an option.
I suppose I should've used a local dealer but this was the price / spec i wanted, which is why I was looking for answers to see if it's something simple but it occurs to me that it might be pretty severe engine damage requiring a rebuild.
As these engines tend to be pretty bulletproof and the few issues are well documented on here, I couldn't find ANY making this noise though.
Post #631611 14th May 2022 12:58pm
Merchy
Cretosx as you are in London, not in the boonies like me, someone on here should be able to recommend a good garage or a good indy specialist in London. With a correct diagnosis, you could ask the seller if they will pay for repairs / collect the car and repair etc. I am sure your consumer rights could mandate this.
I have heard similar noises at sea on engines, there are quite a few possible causes, a definitive answer will not be possible to diagnose remotely, you really need an answer after an inspection / diagnosis. At a rough guess, maybe a problem with the tappets / a valve / cam(shaft) or an injector.
Post #631617 14th May 2022 1:33pm
DrRob
Take it back and get a full refund using consumer rights etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #631632 14th May 2022 3:10pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Thats not right by a very long way. It sounds very much like a cam / lifter issue but it really is not right.
As others have said, take it back, give them a chance to fi=x it or get them to agree taking it to a local specialist at their expense or reject it and have a refund which youre entitled to after giving them a chance to repair it. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #631633 14th May 2022 4:02pm
JayGee
No way is that normal take it right back ASAP. 2012 TDV8 Vogue (L322)
Post #631636 14th May 2022 4:34pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Definitely not right, I would say a piston my self, sounds a bit more than a tappet. Wouldn’t suggest driving far, in case more damage. Good luck with getting a satisfactory resolution.
Post #631645 14th May 2022 6:36pm
Merchy
I would definitely heed QuebecTango's advice, personally I would not drive that car anywhere, it could end up with a lot more damage.
Post #631652 14th May 2022 8:08pm
AJGalaxy2012
I agree it sounds heavier than a valve / lifter but I feel it's too slow to be a piston, valve gear runs at half speed thats what made me head that way.
One thing for sure it does sound nasty. BMW i3 Electric Car
Post #631655 14th May 2022 8:21pm
gettingold
Give it back and soonest before too much time passes. visiting from www.rrsport.co.uk
Post #631671 15th May 2022 6:10am
JayGee
The 2015 consumer rights act means you can demand a full refund if you return it within 30days of purchase if it develops a fault. 2012 TDV8 Vogue (L322)
Post #631673 15th May 2022 6:13am
Page 1 of 3 123>
