![]() | Home > For Sale & Wanted > [For Sale] L322 Paddleshift Modification Kit |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
We have finally got hold of some more paddleshift modification kits for the 2002-2010 L322 Range Rovers.
Jcsh Member Since: 27 Jul 2011 Location: Poitiers Posts: 35 ![]() ![]() |
I fitted these to my 2007 SC and it really does transform the car. Great to hold it a low gear (or even a high gear for economy) and the support is fantastic !
Should also say that there was nothing wrong with the kit, just an error in my installation that led me to asking for support! |
Fitted the steering wheel parts of the kit today - also took the opportunity to remove the switch packs and clean the previous owners detrius... I did use a bit of double sided foam tape to hold the transmitter in place and some assembly tape to hold the extra wiring in place - purely to make reassembly easy without having to worry about things getting trapped, oh, and used a bit of adhesive lined heatshrink in place of the supplied one - there's nothing wrong as such with the supplied one, it's just 'belt & braces'.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
I was also in two minds over the longer delay but after after driving with the longer delay for a while found it to be too long, went back to short delay and in practice its just fine. |
Thanks for that - I did extend the wiring with a PCB header and some leftover twisted pair with a toggle switch at the end of it - TBH, it's fine on the 5 second delay, but I do have the 10 sec. option if there's a German car driver playing silly |
