![]() | Home > Maintenance & Mods (L322) > Removing plastic jacking points |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 ![]() ![]() ![]() |
Anyone know how to remove the plastic jacking point?
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
There is a central pin to knock out then it vertually falls off the car sir |
Got it off but the pin is a goner!
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
is this a plastic pin? and does it have to be pushed in or pulled out.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
The Pin in the middle has to be pulled out - use a suitably strong trim tool as the pin is very tight in there but it does come out.
You will never lever the pin out. It has no head and sits flush with the jacking pad.
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Get the land rover jack out the boot and start lifting the car. Jack pad should just go straight through. Problem solved haha |
Thanks guys, can I have the part no's please |
