Home > Maintenance & Mods (L322) > Full Service
Jon G
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Full Service
Well this Weekends task is a Full Engine Service on my 4.4 TDV8.
So it,s Oil change, Oil, Air, Desiel and Pollen Filters and whilst I’m in there I’m going looking for the slight Oil Leak that’s just shown itself at the Back of the Engine.
Up to now Oil removed with Suction Pump (what a great way of doing it 😎😎😎), reckon I got 9.5 Ltrs out 👍, Doughnut and Throttle Body removed and all the Top end stripped down.
On inspection I found the Turbo Oil Line to be the offending culprit, so the O Rings have been changed for Viton ones.
I have Oil Cooler Gaskets but it’s bone dry and there’s nothing in the ‘V’ so I’m leaving well alone as it’s not showing any signs of leaking.
Started to rebuild now after clearing the gunk out of the Air Intakes but waiting to see if the New Silicon Hoses turn up in the Morning before completing the Job.
Air Filters changed and checked the Air Flow Sensor but they are clean so nothing to do there.
So tomorrow is clean out the Throttle Body but it’s not bad really, change the Fuel Filter and Pollen Filter and put everything back together with Fresh Oil 👍👍
Very please with my progress so far, not as daunting a Job as I 1st thought.
Post #630815 6th May 2022 8:29pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Nice job Thumbs Up
I did those jobs myself not long ago (except oil seals) and like you say, it’s not too bad a job. “Popping off” the plenum is a relatively quick task now I’ve done it a few times.
You mention that the air flow sensors didn’t have any issues, however from what I have gleaned from various internet sources is that it’s worth cleaning with MAF cleaner anyway. They could be dirty but look clean and a spray makes a difference…
I am no mechanic… just passing on advise I’ve picked up myself and given the little effort involved I purchased a can and cleaned mine. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #630820 6th May 2022 8:57pm
JayGee
Don’t forget to clean the MAP sensor on the top of the intake - needs regular unblocking of soot. 2012 TDV8 Vogue (L322)
Post #630825 6th May 2022 9:17pm
Jon G
Don’t have any MAF cleaner, would Electrical Contact Cleaner work ?
I had the MAP Senor out a couple of weeks ago and it was quite clogged up, so it got a good clean out then 👍
Post #630832 6th May 2022 10:13pm
