Home > Technical (L322) > 3.6 tdv8 not starting
Nathan v8
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
hi all
i have changed the RH inlet manifold
got it all back together and running drove ok today bit lumpy as there is a problem with injector 4 but it started ok..
after a drive i changed the leak off seals now it wont start? spins over but wont fire...
it has fuel, gap iid not showing any faults
any help would be great!
thanks
Post #630588 3rd May 2022 10:58pm
TDV8 Paul
When I was messing with my injectors and had the leak off pipes off and on, it took ages to fire up, then suddenly it went 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #630621 4th May 2022 11:58am
dingg1
Fuel line needs priming, don't know the exact procedure on this engine but that's what the problem probably is...
Post #630630 4th May 2022 12:33pm
Nathan v8
is it normal with the return (leak off pipes) off the injectors im getting a good stream of fuel with the ignition on from the return pipes??
Post #630640 4th May 2022 2:16pm
