Home > Maintenance & Mods (L322) > Brembo front calliper refurb kits
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
For those that have refurbed their 6 pot Brembo’s, where did you get the O ring seals from please ?
Post #630600 4th May 2022 9:54am
dhallworth
I bought this kit for my 4 piston Brembo's.
The seller was superb, quick response to my question, quick dispatch and next day delivery.
https://www.ebay.co.uk/itm/263651118044
Might be worth dropping him a message asking if he does the 6 piston ones as he's got thousands of brake parts in his eBay shop.
Post #630606 4th May 2022 10:37am
dhallworth
Just found these in his shop:
https://www.ebay.co.uk/itm/263553049647?ha...Swm51aq6-2
Might well find they're the right ones for your car too so might be worth dropping him a note Smile
Post #630607 4th May 2022 10:40am
Rambles
Thanks David
I think that kit will work
My assumption is that the early 494 and sport 6 pot Brembos are the same as the late 322 6 pot brembos
Pistons are all different sizes
36 38 and 40mm
I had found a few kits like the FRENKIT 236039 that could work
Don’t understand why JLR would sell dust boots for the pistons but not the high pressure seal that sits in the caliper
Post #630614 4th May 2022 11:43am
Rambles
I think this kit on eBay is this kit:
Budweg 204033
Am 99.9% sure it will fit
Asked the vendor as you suggested
Thanks again for the link
Post #630616 4th May 2022 12:29pm
garyRR
The Brembo website gives you the correct specs of the calipers. Good piston manufacturers also publish on their websites. 2015 Range Rover Autobiography 4.4 SDV8
Post #630660 4th May 2022 11:19pm
