Home > Technical (L322) > Tow Bar Help! TDV8 2011 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3135 |
I believe the armature is no longer available brand new so you'd need to look at second hand if you wanted the genuine Land Rover kit. There's usually a few on eBay at any given time.
3rd May 2022 3:38pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
Don`t forget to tell the car you have a 13 pin electrics otherwise the reverse beeper will not turn off when you select reverse when towing. |
3rd May 2022 4:11pm |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 72 |
Might widen your options by going with the 2 7 pin sockets on the car and getting one of the adapters that wire the 2 x 7's into the 13. I'm guessing you have a 13 pin caravan.
4th May 2022 9:30am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
The Westfalia amartures are SUPER expensive (£300+ just for the attachment and not the towbar assembly or wiring).
4th May 2022 10:23pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 593 |
I purchased a second-hand Westfalia tow bar and fitted my self, not a difficult job, a little heavy but easily doable.
4th May 2022 10:53pm |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 |
I did the same as Bigbo and found it an easy approach, the sand blasting and painting (£125) was well worth it as the armature and fittings looked like new.
5th May 2022 6:38am |
All Tow bars have to be type approved so, it baffles me why anyone would buy a 2nd hand Westfalia bar needing new fixings, shot blasting and powder coating at great expense, over just buying a brand new type approved bar.
5th May 2022 9:54am |
