![]() | Home > Technical (L322) > Engine Fault |
During the last couple of days i have had a warning coming up on the dash ENGINE PERFORMANCE REDUCED which causes the car to lose power and slow to 30mph, anyone know what could cause this before it goes to the local Stealer's ......... |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2040 ![]() ![]() |
Mick
Not to worry, is that the new machine in your avatar by any chance ............ |
It's the one of the stealers web site, ut now I've loaded it up it's not actually the one I bourght. But same colour outside. Ours has black leather and piano black trim. I'll take some pics at the weekend, if it's fine. |
Same problem occurred today called out LR assistance, After doing the checks with the ODB scanner it was throwing up 18 faults all linked to the one problem.
Does it "judder" at the same time, and does the check engine light blink/flash? If so it's a failing coil pack. This can be caused by a valve cover gasket or just one of those things.
Does not do anything that you mention, Technician spent a good 45 mins going over everything on the fault codes and showed me where the problem was coming from as when he put a probe in the connector there was no earth switching happening.
UPDATE
UPDATE 2
kin Member Since: 20 Nov 2008 Location: rainy city Posts: 348 ![]() ![]() ![]() |
You TRAITOR Mick ![]() ![]() |
At the moment it's a Maybe.......
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
It's funny how the default position of dealers is always to replace the ECU (one of the most expensive components on the car) when they can't find a fault.
UPDATE 3
UPDATE 4
