Home > Maintenance & Mods (L322) > 100 leds per reverse light brite
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
100 leds per light nice and brite . one of sams mods from you tube with my own tweeks .
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #629818 26th Apr 2022 7:48pm
garyRR
Just be aware as of Feb 2021, it's technically an MOT failure for driving bulbs to be changed to LED, unless the fixture itself is an LED unit. 2015 Range Rover Autobiography 4.4 SDV8
Post #629819 26th Apr 2022 7:58pm
oggy
hi gary that takes about five years before it gets down her in cornwall very slow going pace . and they are a fixed unit not a bulb replacement . thanks for the info anyway new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #629825 26th Apr 2022 8:19pm
peternicholls
REGARDS MOT- At least one reversing light must be fitted and in good working order otherwise it's a MOT failure.
BUT ONLY on vehicles registered after 2009.
Post #629905 27th Apr 2022 5:25pm
garyRR
That has nothing to do with the mandate re LEDs published Feb 21. 2015 Range Rover Autobiography 4.4 SDV8
Post #629907 27th Apr 2022 5:41pm
oggy
that is sounding good peter so my 2007 old banger will be okay so 2009 on then new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #629910 27th Apr 2022 5:56pm
peternicholls
I went around for years with no reverse light on my 2004 focus 🙈🤭
Post #629929 27th Apr 2022 7:42pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Super - bright LEDs in my reversing lights for several years with no issues MOT wise. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #629930 27th Apr 2022 7:47pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Reversing lights can be LED
Is only a problem if switching out halogen headlights to LED for MOT
https://www.gov.uk/guidance/mot-inspection...tion-4-7-1
Post #630063 29th Apr 2022 6:20am
Rambles
Unless of course you swap out the halogen bulb for an LED in your headlight on motorcycles ….
https://www.gov.uk/government/publications...onversions
Post #630064 29th Apr 2022 6:26am
Merchy
During my last MOT, they noticed that my reversing lamps were bright, I told them I had fitted LED bulbs, they were quite happy.
On a separate note, during the test he told me my fog lights were not working, I had to point out that he had switched the master lights switch to auto, in that position the fog lights will not switch on, showed him that bit in the manual, then he was happy, just a point to remember for the MOT.
Post #630071 29th Apr 2022 8:33am
dhallworth
I keep thinking about doing the reversing light mod as with factory tints on my car, reversing at night can be a little daunting if you're not sure where you are.
Where did you source your LED panels from?
Post #630077 29th Apr 2022 10:14am
oggy
hi david i got them from aliexpress new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #630224 30th Apr 2022 6:50pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
@ oggy: can you provide a link please? I've looked on AliExpress and I can't seem to find them. Cheers.
Post #630232 30th Apr 2022 7:20pm
oggy
hi gyre8 the company i got them from was called golden sg car light store from ali 48 led per panel x by 4 59mm x 44mm panels if this is still no good let me know oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #630243 30th Apr 2022 8:01pm
