![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I finally pulled my finger out and corrected my wheel sizes so my speedo is now correct. Next job is to brim the tank, reset my mpg, and then compare it to the next full tank refill for me to have a starting point before adjusting the setting in my IIDTool. Or maybe I’ll change it so the car reports 40MPG+ and drive around with a false sense of economy ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
According to the Gap FAQ it’s one of these two so I changed both… however it was the IPC setting that affected my speedo.
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
Grateful for any help and advice from those much further down the DPF journey than I…
Points to a wiring fault or faulty sensor. Also check the sensor output voltage on the live values 2012 TDV8 Vogue (L322) |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
It doesnt sound like you are over-sooting.
Thanks for the offer! 👍
The number of demanded regens is very low for that mileage. If someone has reset the DPF in a GAP IID tool or similar and not cleaned or replaced the DPF then it would mess with the regeneration schedule. It's also low mileage for the age but not if it's been a city car for most of that and done the school runs it won't have been kind on a DPF system. What's your MPG / distance to empty when you have filled up? 2012 TDV8 Vogue (L322) |
JayGee - I became aware that it was previously a city car a few months back when I contacted the garage where it had been taken and they very kindly sent me all of the invoices for servicing and other work over the 5 or so years they worked on it. They did a forced DPF regen at least twice, if not 3 times in that period. It was therefore no surprise when my EGR started failing and I was lucky to have that changed out under warranty. I also plan to have my DPF taken off and sent for a proper chemical cleaning and as a kind of ‘reset’ under my ownership. However, I don’t want to do that until I have ruled out all other possible failures in the system otherwise I’ll be treating the symptom and not the cause, risking me wasting the money as the DPF fills back up again. I’m confident that my driving style is unlikely to cause DPF problems if the system works as intended.
MPG is not outside the average. External DPF cleaning is to remove ash buildup not soot so if this is a problem it's tackling a possible cause and not a symptom and you can clear soot with regeneration drive cycles or forced methods via the GAP IID if needed. The amount of gunk in the intake doughnut and around the throttle plate would be a good indicator of what's lurking deeper in the engine as a result of excessive short city drive cycles.
Curiosity led me to observing DPF control on mine today. Long drive on the M4 at 65mph and it started at 17g and gradually increased to so no passive regen is happening with the EGT around 300deg. Active regen kicked in at 19.7g , egr valve closed, egt went up gradually to 560deg and soot came down to just over 5g in about 5-10 mins. Successful regen counter didn’t change and demanded regen counter is over 1900 at 145k miles. Also observed egt at higher revs by dropping to 7th and 6th using the paddles and egt didn’t rise with revs. Rises when going up hill so confirms it’s load that controls egt. Never had a dpf light in a year and 17k + miles of driving. 2012 TDV8 Vogue (L322) |
Latest update: it seems to be getting worse! But I now hopefully have some more clues.
Latest update:
I'd suspect the DPF now given high exhaust back pressure and rapid soot load. 2012 TDV8 Vogue (L322) |
