Home > In Car Electronics (L322) > Sat Nav Discs
stu
Sat Nav Discs
can someone please tell me if there are any good cheap places to get an upto date disc for my sat nav?
i have just picked my FFRR up to day, it's a 2005 TD6 Vogue.
i ejected the disc from the boot and put it in my computer. it says 2005 version1 in the info file.
any help would be appreciated in obtaining the newest version. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #62988 7th May 2011 7:27pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Does you car have a touch screen?
Gone - Range Rover Supercharged 2006
Post #62991 7th May 2011 7:34pm
stu
yes the car has the touch screen unit. it is a facelifted 2005 car so if i am not mistaken MY2006.
i am learning every day about the RR so please correct me on tech matters if need be.
can i use BMW discs in the RR?
what is the V32 upgrade about? is it any good what exactly does it do?
sorry for all the questions, but if you don't ask you don't learn. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #62992 7th May 2011 7:35pm
3R10
France
I do not know if I could post them here (legal stuff) but I got both the discs for the Sat Navs! With and without touchscreen! We should check with Martin, the admin and if he says yes, I will gladly upload the discs here! 2000 BMW M5, Avus Blue/LeMans Leather Interior
2006 Range Rover Westminster Java Black
Post #62996 7th May 2011 9:27pm
Vogue
just in case you use the Nav Hac shortcut to input addresses on the move - if you update the disc from the 2005 you will not be able to use the 1791 Nav Hack shortcut - later discs seem to update the Nav software
http://www.rangerovers.net/forum/viewtopic...ht=address
Post #64269 17th May 2011 12:35pm
the new discs do indeed update the firmware and blank out the destination on the move input, but you can get around this by inputting all your destinations before you start moving then these can be accessed on the 'recent destinations' button when you are mobile...
Post #64277 17th May 2011 1:22pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Has anyone bought a disc from this site: link removed by admin as pirated nav discs
I want to update to a 2010 disc from my current 2005 disc - just not too sure about buying a copy....can anyone advise me ?
Thanks
Post #64297 17th May 2011 3:42pm
they are copies of original discs...
pm sent...
Post #64300 17th May 2011 3:54pm
Martin
Site Admin
Link to pirated nav disc site removed - please don't share these links on fullfatrr. Thanks Smile
Post #64311 17th May 2011 5:27pm
