Home > Maintenance & Mods (L405) > Dynamic response system l405
Pw
United Kingdom 2009 Range Rover Vogue TDV8 Barolo Black
Can the ace fluid be changed on 2013 l405?
Post #629800 26th Apr 2022 5:27pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Yes there’s also a filter under the car, its located in the valve block on the drivers side under the plastic sill cover that fastens on the bottom of the sill.
Post #629834 26th Apr 2022 9:57pm
Pw
Thanks, my fluid needs changing but the local main dealer tells me that can’t be done without replacing the entire dynamic.response set up.
Post #629840 27th Apr 2022 5:12am
TJH1985
They replace the container as well as the fluid as part of the 60k service I think, that might be the confusion? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #629841 27th Apr 2022 5:21am
diesel Dave
Not sure what they do at the MD to be honest but I know it can be changed and a new filter fitted, filters are expensive if I remember correct at circa £100 for genuine item.
Post #629846 27th Apr 2022 6:48am
Pw
Thank you. It appears there is some water contamination in my fluid it may be they don’t want to be involved.
Post #629850 27th Apr 2022 7:22am
