![]() | Home > Technical (L322) > GAP IID tool - does it show vanos adaptation values (M62TU) |
glenhendry Member Since: 14 Jan 2019 Location: Brisbane Posts: 12 ![]() ![]() ![]() |
Turns out that the IID scan tool shows the cam position alternating between 255 and 0 degrees when the cam is at rest, ie, not being moved by the vanos. Once I adjusted my cam timing wheels to get them back with the M62TUs adaption range (not over 12%) then vanos's started working again and the values showing up on IID were sensible. |
